Node credentials setup
To connect to a registered node, enter the node number, username, and password. Passwords are stored securely in the macOS Keychain.
For private nodes that are not listed in the AllStar directory, specify a host and port number in the advanced section.
Node credentials during setup
See Node credentials for server-side configuration if you manage your own node.
