Node credentials
Transceive requires a username and password to authenticate with a node. If you own a node, add credentials on the server. You can also verify that public authentication is configured if you want operators to connect without individual accounts.
Add a user
Add this section to /etc/asterisk/iax.conf:
[user_name] ; <- change this to desired username
type=user
context=transceive
auth=md5
secret=Sekret ; <- change this to desired password
host=dynamic
disallow=all
allow=ulaw
allow=gsm
transfer=no
Add this context to /etc/asterisk/extensions.conf:
[transceive]
exten => ${NODE},1,rpt(${NODE}|X) ; NODE is normally already defined as your node number
For AllStarLink versions prior to v3:
[transceive]
exten = 1234,1,Rpt,1234|X ; <- Change 1234 to your node number
Restart the node after you modify the configuration.
