Automatic unlinking
Linked nodes repeat audio with each other. Linking multiple nodes without care can bridge separate networks. Only do so with explicit permission from the node owners.
By default, Transceive assumes you want one direct link at a time. When you link to a new node while still linked to another, Transceive reminds you that the previous link will be removed first.
Selecting Do not show this message again hides the dialog. Automatic unlinking still occurs.
To link multiple nodes intentionally, see Turn off automatic unlinking.
