Public authentication configuration
The default AllStar server configuration includes a public authentication section. If your installation is missing it, add the following.
In /etc/asterisk/iax.conf:
[allstar-public]
type = user
context = allstar-public
auth = md5
secret = allstar
disallow = all
allow = ulaw
allow = gsm
requirecalltoken = no
In /etc/asterisk/extensions.conf:
[allstar-public]
exten => s,1,Ringing
exten => s,n,Set(RESP=${CURL(https://register.allstarlink.org/cgi-bin/authwebphone.pl?${CALLERID(name)})})
exten => s,n,Set(NODENUM=${CALLERID(number)})
exten => s,n,GotoIf($["${RESP:0:1}" = "?"]?hangit)
exten => s,n,GotoIf($["${RESP:0:1}" = ""]?hangit)
exten => s,n,GotoIf($["${RESP:0:5}" != "OHYES"]?hangit)
exten => s,n,Set(CALLSIGN=${RESP:5})
exten => s,n,Wait(3)
exten => s,n,Playback(rpt/node|noanswer)
exten => s,n,Saydigits(${NODENUM})
exten => s,n,Set(CALLERID(name)=${CALLSIGN})
exten => s,n,Set(CALLERID(num)=0)
exten => s,n,Rpt(${NODENUM}|X)
exten => s,n,Hangup
exten => s,n(hangit),Answer
exten => s,n(hangit),Wait(1)
exten => s,n(hangit),Hangup
Restart the node after you modify the configuration.
In the AllStar portal, set your node to Allow Web Transceiver access. This adds the (wt) mark next to your node in the directory so operators know it accepts public connections.
