Setup assistant
The setup assistant walks you through your callsign, authentication method, and first node connection when you launch Transceive for the first time.
What you’ll configure
- Identification — your callsign
- Authentication type — AllStar account or node credentials
- Connect with public authentication or Connect with node credentials
You can run through the assistant again later from the Connections menu if you add another node.
