Audio test
Audio quality is hard to judge alone. If you control the node you connect to, link to a parrot node that repeats your transmission so you can listen and adjust levels.
A reliable public parrot node is 42565 from DVSwitch. Connect to node 42565 in Transceive.
Use the Audio monitor while you transmit to watch input levels.
